Electronic Circuits Forum
Electronic circuit & projects discussion forum for Electronic enthusiasts to share and discuss. Place to discuss about electronic circuits, projects and hobby stuff.
PLEASE HELP IDENTIFY
Postby jafomc » Fri Aug 17, 2012 10:53 am
THIS IS ON THE CHARGING END OF THE GATE OPENER BOARD, ANY HELP TO IDENTIFY, I THANK YOU IN ADVANCE, DAVE
THE PARTS READ SD109 ON THE TOP
MIGHTY MULE CIRCUIT BOARD2.jpg (179.23 KiB) Viewed 1219 times
jafomc
Re: PLEASE HELP IDENTIFY
Postby pebe » Fri Aug 17, 2012 3:06 pm
I cannot find a data sheet for the SD109. It is probably a reference code used between the board manufacturer and his supplier. As it's in a charging circuit, the SD would seem to mean 'silicon diode' with the '109' being its ratings. The 'D5' etc on the board would appear to confirm that it's part of a bridge rectifier circuit.
See if you can establish what voltage and current the transformer gives, then look for a suitable diode in any of the many component supplier's sites.
