Analog circuits
Analog circuits
Postby cconly » Thu Aug 18, 2011 6:20 am
Main article: Analog electronics
Hitachi J100 adjustable frequency drive chassis.Most analog electronic appliances, such as radio receivers, are constructed from combinations of a few types of basic circuits. Analog circuits use a continuous range of voltage as opposed to discrete levels as in digital circuits.
The number of different analog circuits so far devised is huge, especially because a 'circuit' can be defined as anything from a single component, to systems containing thousands of components.
Analog circuits are sometimes called linear circuits although many non-linear effects are used in analog circuits such as mixers, modulators, etc. Good examples of analog circuits include vacuum tube and transistor amplifiers, operational amplifiers [url=http://www.[banned].com/[banned].html][banned] Powerleveling[/url]and oscillators.
One rarely finds modern circuits that are entirely analog. These days analog circuitry may use digital or even microprocessor techniques to improve performance. This type of circuit is usually called "mixed signal" rather than analog or digital.
Sometimes it may be difficult to differentiate between analog and digital circuits as they have elements of both linear and non-linear operation. An example is the comparator which takes in a continuous range of voltage but only outputs one of two levels as in a digital circuit. Similarly, an overdriven transistor amplifier can take on the characteristics of a controlled switch having essentially two levels of output.
[edit] Digital circuitsMain article: Digital electronics
Digital circuits are electric circuits based on a number of discrete voltage levels. Digital circuits are the most common physical representation of Boolean algebra and are the basis of all digital computers. To most engineers, the terms "digital circuit", "digital system" and "logic" are interchangeable in the context of digital circuits. Most digital circuits use a binary system with two voltage levels labeled "0" and "1". Often logic "0" will be a lower voltage and referred to as "Low" while logic "1" is referred to as "High". However, some systems use the reverse definition ("0" is "High") or are current based. Ternary (with three states) logic has been studied, and some prototype computers made. Computers, electronic clocks, and programmable logic controllers [url=http://www.[banned].com/[banned].html]Buy [banned] Credits[/url](used to control industrial processes) are constructed of digital circuits. Digital Signal Processors are another example.
Building-blocks:
Logic gates
Adders
Flip-Flops
Counters
Registers
Multiplexers
Schmitt triggers
Highly integrated devices:
Microprocessors
Microcontrollers
Application-specific integrated circuit (ASIC)
Digital signal processor (DSP)
Field-programmable gate array (FPGA)
cconly
Postby clark » Fri Aug 19, 2011 9:13 am
Be familiar with analog electronics, digital electronics and MCU system,Troubleshooting analog circuits on the classics, from National Semiconductor, Electronics Engineers required.
clark
