Temperature sensor without using microcontroller
Postby obaid123 » Tue Apr 26, 2011 4:01 pm
i need to know which IC's should i use to display the temperature in 7-segment display.. i am using lm35 and adc0804 what should i do next??
mir@
obaid123
Postby pebe » Tue Apr 26, 2011 8:02 pm
Change your mind and use a microcontroller - it would be much easier :?
the project assigned requires no use of micro controllers.
Postby obaid123 » Wed Apr 27, 2011 6:18 am
the project requirement is to contstruct it without micro controller.
mir@
obaid123
Postby pebe » Thu Apr 28, 2011 9:03 am
If this is a project requirement then surely its purpose is to test your knowledge and ingenuity. It's not likely to achieve its aim if someone does the project for you.
Postby admin » Thu Apr 28, 2011 1:39 pm
Hi obaid123,
You could use a ICL7107 details are here:
http://www.intersil.com/products/device ... pn=ICL7107
It has an A/D which can convert voltage from your LM35 and digitize it to display on the LED. All you need would be a scaling circuit in between which would typically be an opamp amplifier.
This should be enough hints for you to do it on your own.
regards,
Admin.
admin
Site Admin
Postby obaid123 » Thu Apr 28, 2011 8:08 pm
thankx.....
mir@
obaid123
Users browsing this forum: No registered users and 17 guests
