Adding extra LED lights
Postby xxkakuraxx » Wed Oct 12, 2011 12:08 am
Hey guys, sorry if this sounds dumb, but I haven't found much information to help me. So hopefully one of you can.
I was given a small circuit board that contains 5 LED lights, a timer, and the resistors, etc. This guy wanted me to add on 5 more LED lights. This is a small board, and I can't figure out how to go about doing this.
Any help would be wonderful!
xxkakuraxx
Postby Brocke » Wed Oct 12, 2011 6:25 am
its been a long time since i left this field. i hope you get through this test.
Brocke
0.1Hz-100kHz Adjustable Frequency Generator 7.83Hz Schumann Resonance Generator
$17.94
0.1Hz-100kHz Adjustable Frequency Generator 7.83Hz Schumann Resonance Generator picture0.01Hz-200Khz Adjustable Frequency Generator for Healing Schumann Sine Waves Res
$37.99
0.01Hz-200Khz Adjustable Frequency Generator for Healing Schumann Sine Waves Res pictureSystem Sensor HWL-LF Low-Frequency Wall Horn White, 10-Pack
$397.00
System Sensor HWL-LF Low-Frequency Wall Horn White, 10-Pack pictureVariable Frequency Drive VFD Motor Speed Control Inverter 3 Phase 7.5 KW
$135.00
Variable Frequency Drive VFD Motor Speed Control Inverter 3 Phase 7.5 KW picture
