Smoke detector using IR sensors?
Postby johnjameson » Mon Jan 30, 2012 12:08 am
Just wondering guys how hard would it be to make a smoke detector using this development kit?
http://www.silabs.com/products/senso...rSliderEK.aspx
They even give you a pdf on the topic
http://www.silabs.com/Support%20Docu...Docs/AN541.pdf
johnjameson
Re: Smoke detector using IR sensors?
Postby Thomas W » Thu Feb 09, 2012 11:52 am
The links are not working here?...
Thomas W
BIFET DXD369 Solenoid Valve 24V 2.3W 3/64" Orifice 125 PSI MOPD Air
$37.50
BIFET DXD369 Solenoid Valve 24V 2.3W 3/64Solenoid Repair kit for Dentsply Cavitron 124 131, 132, 121, 136, 137, 310, 1000
$39.95
$174.99
Parker GP600 G-23 77310 Brass Solenoid Valve 120V 9W Sukup Grain Dryer USA pictureOEM Stanadyne Roosa Master 26214 DB Diesel Fuel Injection Pump Shut Off Solenoid
$75.00
OEM Stanadyne Roosa Master 26214 DB Diesel Fuel Injection Pump Shut Off Solenoid picture
