Does anyone know how to do this?
Postby Chris230291 » Sun Mar 25, 2012 7:00 pm
Hello. What i want is a circuit that can monitor the voltage on the "+" pin of a 3 pin fan header on a computer motherboard. Then "copy" that voltage and replicate it from an external power source (PC power supply), but with enough current to run anywhere up to 8 fans (for example). My plan is to have one fan connected directly and it's speed controlled by the computer. The circuit will monitor the "+" output and replicate it for other fans, allowing me to run multiple fans at the same speed as the one directly connect fan. I hope that makes sense?
I know nothing about designing electronics, but if someone has a solution i am more than capable of assembling it.
Chris
Chris230291
Intel® UP Xtreme 1145GRE Embedded Dev SBC 32GB RAM 512GB SSD Kit
Intel® UP Xtreme 1145GRE Embedded Dev SBC 32GB RAM 512GB SSD Kit pictureRAM Jack 10 Ton Capacity 10" Stroke Hydraulic Piston Frame Machines & towers
$274.99
RAM Jack 10 Ton Capacity 10Allen-Bradley 1775-ME8 Memory Module
$984.62
Allen-Bradley 1775-ME8 Memory Module pictureRevolution Pi by Kunbus RevPi Connect 5 | 8GB RAM | 32 GB eMMC
$449.95
Revolution Pi by Kunbus RevPi Connect 5 | 8GB RAM | 32 GB eMMC picture
