Using bipolar transistor for wwitching
Postby nissim » Sun May 06, 2012 9:55 am
Hi There
I am trying to switch an LCD display from a micro port .
My circuit works fine without a load .
When I use LCD as a load the transistor does not turn off and instead 0vdc
I get 3.75VDC.
I tried 10K resistor across the load but same problem
I would appreciate if someone could explain me the reason for the problem and suitable solution .
If bipolar is not a suitable solution I will consider using N MOSFET
Many thanks
Nissim
Circuit to switch a load using Bipolar transistor
Switching LCD.jpg (94.79 KiB) Viewed 5419 times
nissim
Re: Using bipolar transistor for wwitching
Postby pebe » Sun May 06, 2012 10:58 am
The feed from the micro to Q2 base should include a resistor to limit the base current. Perhaps Q2 has been damaged and has gone s/c from emitter to collector and is keeping Q1 switched on.
Other than that, there is no reason for the circuit not to work
$64.95
$82.88
$349.99
ASUS Z8PE-D18 Dual Xeon Server Motherboard 2x E5620 CPU 144GB RAM 12x12GB LGA136 pictureIntel Xeon E5-2650 V3 2.3GHz 10-Core LGA 2011-3 Server CPU Processor
$16.99
Intel Xeon E5-2650 V3 2.3GHz 10-Core LGA 2011-3 Server CPU Processor picture
