White LED Driver Circuit
Postby james_sgp » Tue Aug 07, 2012 12:57 am
I`m trying to build an LED driver circuit for a torch, I have tried using a Micrel MIC2291 in both Boost & SEPIC configuration but it doesn`t seem to keep the current stable. The power source is a single 18650 LiPo battery, driving a CREE XP-G LED; I`m trying to drive it at between 800~1000mA; would appreciate anyones help in recommending an IC or circuit.
I want to make my own rather than buy as I have a limited space constraint for the PCB (max dia. 19mm , with a dia. 3mm hole in the middle).
James
james_sgp
Users browsing this forum: Google Adsense [Bot] and 6 guests
Siemens Q2100P 100 Amp 2 Pole Type Circuit Breakers
$37.95
Siemens Q2100P 100 Amp 2 Pole Type Circuit Breakers  pictureSiemens Simovert Masterdrive 6SE7015-0EP50-Z USED
$888.33
$275.00
Siemens Simodrive LT-Modul 6SN1124-1AB00-0AA1 pictureSiemens 6GK5876-4AA00-2DA2 Scalance SIMATIC NET New in box
$745.00
Siemens 6GK5876-4AA00-2DA2 Scalance SIMATIC NET New in box picture
