metal detector problem
Postby jtjohnsontellis » Fri Aug 03, 2012 6:31 am
dear sir
im extremely happy with all the help that you are providing to students like us
im a student of 1st yea engg and i need the metal detector circuit that u have mentioned in ur site for ma project.but it seem to encounter some problem wich i cant recognize.when i connect the speaker i can hear the noise tat is amplified and continues to remain the same even if the trimmer is tuned,i really need ur suggestion 4 this
plz help.thak u
johnson
9738610416
india
http://www.next.gr/inside-circuits/meta ... l6642.html
plz check and suggest me wat changes i can do to make it work properly..thank you
Last edited by jtjohnsontellis on Mon Aug 06, 2012 10:06 am, edited 1 time in total.
jtjohnsontellis
Re: metal detector problem
Postby pebe » Mon Aug 06, 2012 10:35 am
What do you mean by 'noise'? Is it random noise or an audio tone?
Postby jtjohnsontellis » Wed Aug 08, 2012 1:30 pm
noise in the sense i get output in the speaker even when the meatl s not closer by.the circuit was suppose to give zero signals as output wen the metal is not near by(superheterodyne principle)but in this case it gives an output...even if the variable capacitance is tuned it doesnot make any difference.so i request u if u can suggest me some other circuit which is really efficient or suggest any changes in this circuit./
thank u very much 4 ur valuable replies
thank u
johnson
jtjohnsontellis
Postby pebe » Thu Aug 09, 2012 8:03 am
You haven't answered the question so it's not easy to diagnose the problem.
Again, What kind of noise is it? Does it sound like a hiss, or more like a clean note as when a flute is played? And can its level be varied with the volume control?
DC12V 2-Position 5-Way Solenoid Valve Junction Box for Pneumatic Systems
$28.60
DC12V 2-Position 5-Way Solenoid Valve Junction Box for Pneumatic Systems pictureSolenoid Repair kit for Dentsply Cavitron 124 131, 132, 121, 136, 137, 310, 1000
$39.95
Solenoid Repair kit for Dentsply Cavitron 124 131, 132, 121, 136, 137, 310, 1000 pictureOMKC-2 SPORLAN SOLENOID COIL 208-240V NEW
$39.73
OMKC-2 SPORLAN SOLENOID COIL 208-240V NEW pictureNITRA AVS-5312-24D Pneumatic Solenoid Valve 5-Way/2-Position 24V DC
$80.00
NITRA AVS-5312-24D Pneumatic Solenoid Valve 5-Way/2-Position 24V DC picture
