circuit for voltage offset
Postby bretcon » Sat Sep 15, 2012 6:41 pm
I have two 0-5 volt signals that are variable. I need to intercept these two signals and offset the voltage at certain voltages. The out put would still be 0-5 volts. can anyone help.
bretcon
Re: circuit for voltage offset
Postby pebe » Sun Sep 16, 2012 4:11 pm
Can you give a bit more detail?
Are the signals AC or DC? If AC, are they 0-5V RMS or peak to peak?
Are the signals to be mixed, or handled separately to give two outputs?
Quote: "I need to intercept these two signals and offset the voltage at certain voltages".
What are the certain offset voltages?
An explanation of what you are trying to do would be helpful.
Postby larry80 » Thu Sep 20, 2012 2:52 pm
can you give us more details ? what does your project receive signals from ? is it low frequency ? ..
[url=http://www.7pcbassembly.com/turnkey-pcb-assembly.php]circuit board assembly[/url]
larry80
Users browsing this forum: Majestic-12 [Bot] and 1 guest
$53.99
$90.00
EMERSON SOLA SDP 5-5-100T POWER SUPPLY picturePower-One (Bell Power) Model: MAP55-4003 Power Supply.
Power-One (Bell Power) Model: MAP55-4003 Power Supply. pictureMean Well NMP650 - EHKK-03 Power Supply with 12V , 24V , 48V Outputs
Mean Well NMP650 - EHKK-03 Power Supply with 12V , 24V , 48V Outputs picture
