FETS?
FETS?
Postby rmjr » Wed Nov 21, 2012 2:57 am
Hello,
There is a mosfet called "Depletion/Enhancement Mosfet" which can be used in two modes either depletion or enhancement.
However there is another type of mosfet called "Enhancement mosfet" which is the one I am looking for and shown at 12:30 of the following video:
http://www.youtube.com/watch?v=NSD7n...hannel&list=UL
This type of mosfet simply accepts positive threshold voltage at the gate which allows an N-channel to be formed by minority carriers connecting the drain to the source. The higher the gate voltage above the Voltage threshold, the more minority carriers form creating a bigger N channel thus allowing more current through drain/source. Is this exactly what the 2N7000 part does?
thank you so must for your help !
rmjr
$173.56
Power Sentry PS1055LCP LED Emergency Driver Inverter Battery Backup picture9600 Series Vector Control Frequency Inverter VFD 380V 3 Phase Input Output
$329.99
9600 Series Vector Control Frequency Inverter VFD 380V 3 Phase Input Output picture
