Sound Project DC power supply question
Postby BMK » Tue Dec 04, 2012 3:33 pm
I am working on a sound application project for my model railroad and have questions regarding the DC power supply requirements.
Based on the documentations, when 5VDC input is required, I need to utilize two (2) 1N4001 diodes in series to one of the two DC input pins. Not sure why put OK that is what I will do. However, if I have the unit connected to my 5VDC supply and the USB plugged in at the same time is their any conflicts?
The sound module is a WT588D-U
Thank you for your response
Brian Krupicka USA
BMK
Re: Sound Project DC power supply question
Postby pebe » Tue Dec 04, 2012 4:15 pm
Without sight of the documentation and your circuit/ wiring arrangement, it is not possible to give an answer.
$29.99
$185.00
Hydraulic Leveling and Slide Out Replacement Motor and Polarity Solenoid pictureCustom Dual Channel DC Test Control Box AC Powered Tested Working
Custom Dual Channel DC Test Control Box AC Powered Tested Working pictureMagne-Tron Instruments 700 ER Wafer Resistivity / Conductivity Tester Probe
$420.00
Magne-Tron Instruments 700 ER Wafer Resistivity / Conductivity Tester Probe picture
