Power Factor
Power Factor
Postby 73polarbear » Sun Jan 06, 2013 10:42 pm
If a coil with a .2 lagging power factor is connected in series with 300 watt incandescent lamp to supply that lamp with 120 volts from a 208 volt, 60 Hz power supply, what is the voltage across the coil terminals? Can anyone point me in the right direction?
73polarbear
Re: Power Factor
Postby moki » Sat Jan 26, 2013 5:22 pm
Not that simple. You will have to calculate the inductive reactance (XL). To do this you must know the inductance (L) of the coil. XL = 2 x pi x f x L. So for example the inductance of your coil is 100 milli henry, XL will be 2 x 3.14 x 60 x .1. That will give XL as 37.68 ohm. You will then have to calculate the volt drop across the coil using ohms law v = I x R. So you must know what current the lamp draws as well. Some circuits use a capacitor to drop voltage. A typical example is some daylight sensing switches. Its fine as long as the current is not too high. The formula is then Xc (Capacitive reactance) = 1 divided 2 x pi x f x C. Capacitance is in farads.
Hope this helps or gives you a start!!
moki
Siemens Simovert Masterdrive 6SE7015-0EP50-Z USED
$888.33
$275.00
Siemens Simodrive LT-Modul 6SN1124-1AB00-0AA1 pictureSiemens 6ES7212-1AG50-0XB0 PLC CPU Module 6ES72121AG500XB0 New DHL Shipping
$168.54
Siemens 6ES7212-1AG50-0XB0 PLC CPU Module 6ES72121AG500XB0 New DHL Shipping pictureSIEMENS 6ES7 214-1HG40-0XB0 SIMATIC S7-1200 PLC CPU Unit New in box
$299.00
SIEMENS 6ES7 214-1HG40-0XB0 SIMATIC S7-1200 PLC CPU Unit New in box picture
