Inverting Adder
Inverting Adder
Postby pwm_111 » Sun Jan 27, 2013 10:20 pm
Hello! I am trying to answer the following question:
Design an circuit with operational amplifiers that has the following output function:
Vo=2*V1+10*V2+11*V3-V4
Shoud i use the inverting adder?
Using three different voltage sorces V1,V2,V3 and V4 ,an OpAmp and a 4 resistors(R1 to R4) and a feedbak resistor.
So the expression for the output of and adding inverter is given by:
V0=-(Rf/R1)-(Rf/R2)-(Rf/R3)-(Rf/R4)
So i could use Rf=10k ,R1=5k,R2=1k,R3=1,1k and R4=10k
The problem is then Vo=-2V1-10V2-11V3-V4....Shoud i use and non-inverting adder,conecing the resistors to the non-inverting input?
pwm_111
$29.99
XTGSP2 Tone Generator and Speaker Polarity Tester pictureStainless 308L-16 1/16 Stick Electrode 10lbs Very hard to find MFG USA
$229.00
Stainless 308L-16 1/16  Stick Electrode  10lbs Very hard to find MFG USA pictureMagne-Tron Instruments 700 ER Wafer Resistivity / Conductivity Tester Probe
$420.00
Magne-Tron Instruments 700 ER Wafer Resistivity / Conductivity Tester Probe picturePC218 Phase Polarity Tester Checker Detector Audio Speaker Mic Sound Testing
$175.80
PC218 Phase Polarity Tester Checker Detector Audio Speaker Mic Sound Testing picture
