Current Source Project Ideas
Postby ggbc11 » Tue Apr 23, 2013 7:45 am
I'm doing a project for my final year of BEng. As part of it I need to design a module that can take mains supply,ie 240/110VAC 50Hz, and output 0-100A at a resolution of 100mA controlled by a PIC.
My current solution is to have a variac actuated by a stepper motor controlled by a feedback loop via a current transformer (CT). So the PIC will recieve a set point value ie. 50A, and move the stepper motor comparing the set point to the input from the CT with some kind of PID control. I think this will work but itll be heavy as this is supposed to be a portable device.
I work with distribution and control so three phase theory and protection is more my thing not power electronics but I have some understanding. I would like to ask if anyone could point me in the right direction of a lighter, electronic solution. Im not asking for blueprints as I will research and learn anything I need to make a good project, just a rough concept or research area.
My last project was a single phase inverter controlled by a PIC, could this be backed by a current amplifying circuit and followed by a transformer?
Would appreciate any advice on this,
GG
ggbc11
Re: Current Source Project Ideas
Postby pebe » Tue Apr 23, 2013 12:27 pm
What is the maximum voltage you want at 100A?
Postby ggbc11 » Tue Apr 23, 2013 3:34 pm
the input inpedance the project is feeding is around 20mOhms, so about 2 volts.
ggbc11
silicon controlled thyristor scr
$80.00
silicon controlled thyristor scr picturePower Transistor, Mosfet, Thyristor and Voltage Regulator Assortment Kit, 82
$54.99
Power Transistor, Mosfet, Thyristor and Voltage Regulator Assortment Kit, 82 pictureSCR Thyristor SKN6000/04 for Semikron VF1.20V 14KA
$118.84
$185.00
5000A Phase Control Capsule Thyristor Convex Type SCR Silicon Controlled Ballast picture
