I'm really amateur. Making to flash a 12v led...
Postby monkeyisland3g » Sat Sep 28, 2013 9:57 am
Sorry, I search in the web but mostly I found only 3v and 6v circuits.
Although I'm not scared to solder components, I'm really new in electronics, I'd like to make Flash this 12v-led arrow
[url]http://www.ebay.co.uk/itm/271265853156?var=570181454985&ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649[/url]
when I switch it on.
In the cheapest/smallest way it could be done.
The project is to make a turn-light on my bicycle with this battery type:
[url]http://www.ebay.co.uk/itm/190900045894?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649[/url]
and this switch controller:
[url]http://www.ebay.co.uk/itm/390628419797?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649[/url]
. Thanks!!!!!!
Last edited by monkeyisland3g on Sat Sep 28, 2013 1:58 pm, edited 1 time in total.
monkeyisland3g
Re: I'm really amateur. Making to flush a 12v led...
Postby pebe » Sat Sep 28, 2013 11:02 am
Hi, welcome to the forum.
This is probably what you need.
http://www.ebay.co.uk/itm/Flash-Strobe- ... 1c35c70d3c
If not, can you work from a circuit and are you prepared to make up a flasher using an IC?
Postby monkeyisland3g » Sat Sep 28, 2013 11:18 am
Wow! thanks very much Pebe. That is what I want, probably is cheaper than ic separated components.
Last question, do I need two of these controllers to make flash each Led-arrow or can i connect 2 arrows to 1 single controller and make flash the arrows separately? thanks!
monkeyisland3g
LCD Digital Multimeter Voltmeter Ammeter Ohmmeter Volt AC DC Tester Lead Meter
$5.95
LCD Digital Multimeter Voltmeter Ammeter Ohmmeter Volt AC DC Tester Lead Meter pictureAnalog Panel AMP Current Ammeter Meter Gauge DH-670 0-50A DC & Shunt
$12.62
Analog Panel AMP Current Ammeter Meter Gauge DH-670 0-50A DC & Shunt pictureRadioShack Clamp-On AC Ammeter with Detachable Multimeter Model 22-602 With Case
$21.50
RadioShack Clamp-On AC Ammeter with Detachable Multimeter Model 22-602 With Case pictureDC Amperes Analog Panel Meter Ammeter Gauge 0-1.0A Model/MPN DC AMPERES
$12.99
DC Amperes Analog Panel Meter Ammeter Gauge 0-1.0A Model/MPN DC AMPERES picture
