Crock Pot Distillation
Postby SpiderCiders » Tue Dec 17, 2013 4:38 pm
I am attempting to convert a crock pot into a small distillation unit for extracting essential oils. As such, I need for the temperature switch to run on unfixed positions so that I can adjust the temperature. Currently the cord connects to a switch which allows for the unit to run one or two heating elements. I would like to run both elements together full time and be able to control the temperature output. The crock pot is a Rival 3350/2 with the following specifications...
180-250 watts
120 V 50-60 hz AC only
If possible I would also like to get a touch more heat out of the unit. It currently goes to about 187 degrees F and I would like to see it reach 200.
My question is, what sort of switch would be appropriate for modifying the unit thusly?
I am not a regular electronics meddler, just on occasion, so please speak newbie to me. :)
SpiderCiders
Users browsing this forum: Google Adsense [Bot] and 4 guests
$1.80
$9.55
5/10PC Diode Bridge Rectifier KBPC5010 50A 1000V Power Rectifier Diode KBPC 5010 picture4 Terminals Single-Phase Diode Bridge Rectifier MDQ 100A Amp High Power 1600V
$11.95
4 Terminals Single-Phase Diode Bridge Rectifier MDQ 100A Amp High Power 1600V pictureMDQ400A Rectifier Diode, 1 Pcs Bridge Rectifier 400A 1600V Diodes, Black
$48.68
MDQ400A Rectifier Diode, 1 Pcs Bridge Rectifier 400A 1600V Diodes, Black picture
