2 second trigger circuit timer
Postby ese2709 » Sat Dec 21, 2013 2:45 am
Hi..
i have a home theater player and lcd tv... when i on tv the home theater will on together..
in my mind i want to use usb port from TV that when i on TV.. 5V from usb port (usb power will on until i off TV) i will use for the signal input to timer circuit. if the circuit detect signal from TV, it will on a relay for 2 second then off the relay. this relay is connect to standby switch of home theater player. then if i off TV so the power from usb is off and circuit detect no signal from TV, it will on the relay for 2 second then off. this will make the home theater player go to standby mode. the power source for the circuit i will connect to standby power from home theater power. that is my teory.
so someone can help me how to buit the circuit. if the relay can change to IC is better.
ese2709
$1.80
10pcs  1N4007 Rectifier Diode 1A 1000V - US Seller  pictureOEM Regulator Rectifier Assy 31750-Z2E-803 20AFor Honda GX440 GX630 GX660 GX690
$94.55
OEM Regulator Rectifier Assy 31750-Z2E-803 20AFor Honda GX440 GX630 GX660 GX690 picture5/10PC Diode Bridge Rectifier KBPC5010 50A 1000V Power Rectifier Diode KBPC 5010
$7.84
5/10PC Diode Bridge Rectifier KBPC5010 50A 1000V Power Rectifier Diode KBPC 5010 pictureAVR Automatic Voltage Regulator For 3Kw-8Kw Generator Rectifier Half Moon Style
$18.99
AVR Automatic Voltage Regulator For 3Kw-8Kw Generator Rectifier Half Moon Style picture
