Quick quesiton about alarm system battery
Postby geryuuu » Fri Feb 28, 2014 5:56 pm
So I built a small simple alarm system, with a couple PUT's and NPN's and a Relay. The schematic recommends a 12v battery be used. But I was wondering if I could just use a simple AC-DC adapter instead of a rechargeable battery. I was trying to think as to why use a battery, Im guessing incase the power goes out , the battery can still power the alarm system. But please let me know what you all recommend :)
geryuuu
Re: Quick quesiton about alarm system battery
Postby Sebi » Fri Mar 07, 2014 3:30 pm
the alarm systems work always with uninterruptible power supply. The simple wall-wart adapters contains only a bridge rectifyer and a capacitor, so the output voltage depend from load and mains voltage.
The minimum requirement a stable supply with 13,8V output, and a small maintenance-free Pb-accu with parallel (puffer) mode.
Sebi
Hewlett-Packard 8447E Amplifier 0.1-1300 MHz 22 dB Gain 0.1 W 8.5 dB
$175.00
Hewlett-Packard 8447E Amplifier 0.1-1300 MHz 22 dB Gain 0.1 W 8.5 dB pictureSKAR AUDIO USED SK-M9005D 900 WATT 5-CHANNEL CLASS D MINI CAR AMPLIFIER
$191.99
SKAR AUDIO USED SK-M9005D 900 WATT 5-CHANNEL CLASS D MINI CAR AMPLIFIER pictureSKAR AUDIO USED SK-M4004D 400 WATT 4-CHANNEL CLASS D MINI CAR AMPLIFIER
$137.49
SKAR AUDIO USED SK-M4004D 400 WATT 4-CHANNEL CLASS D MINI CAR AMPLIFIER pictureKistler Type 5010B Dual Mode Amplifier
$99.99
Kistler Type 5010B Dual Mode Amplifier picture
