Resolution in texas Instrument Energy-meters (Calibration)
Postby CaEngineer » Mon Mar 17, 2014 8:59 pm
I am working on a Texas Instrument's Board which has MSP430f47197 and the has the following code (C files). The current resolution for kWhs is .01 but I need higher than this. I changed the code to some extent but unfortunately I could not hit it to what I need!
By any chance has anyone worked on the resolution and calibration part of an energy meter?
CaEngineer
$7.77
‌USB Tester Type-C PD Digital Capacity Meter 8A Voltage Current Monitor Power pictureAutomated Logic SE6104SP BACnet Control Module SE6104SP HVAC Controller
Automated Logic SE6104SP BACnet Control Module SE6104SP HVAC Controller pictureLincoln Variable Voltage PC Board Assembly L5394-2
$380.00
Lincoln Variable Voltage PC Board Assembly L5394-2 pictureB&K Precision Hv 44A High Voltage Detector, Analog
$169.99
B&K Precision Hv 44A High Voltage Detector, Analog picture
