Using 60-0-60 transformer & lm317s as variable pwr supply
Postby YorkshireDave » Sat Apr 05, 2014 2:50 pm
I've a great 60-0-60 transformer from a mobility scooter power supply plus a bag of LM317 regulators and wondered how I can marry them to make a variable power supply. Any suggestions very welcome :D
YorkshireDave
Re: Using 60-0-60 transformer & lm317s as variable pwr suppl
Postby pebe » Mon Apr 07, 2014 4:38 pm
What sort of outputs are you looking for? What voltage and current ranges?
$27.04
$13.63
$85.00
SDC Electromagnetic 650 LB Lock 1581SNDV Exit Check Delayed Egress System picture12V 24V DC 2.5-150KG Electric Lifting Magnet Electromagnet Solenoid Holding Coil
$38.44
12V 24V DC 2.5-150KG Electric Lifting Magnet Electromagnet Solenoid Holding Coil picture
