pedestrian crossing circuit
Postby noorb92 » Tue Mar 11, 2014 3:59 pm
pedestrian crossing circuit?!!!!?
My project will be having a button in siganl A ( for crossing the road). When this buton is pressed 5 seconds later the main signal B ( the big signal for cars) will turn red and after 2 seconds signal A will turn green for 10 seconds along with a beeping sound. When the 10 seconds are over it turns into red and the beeps stop. 2 seconds later the signal B turns green again.
And its connected to a PV system which means the system works with solar energy.
My question is, how do I design a timer circuit for the signals I know I need components such as ic 555 , resistors and much more.
what will be the circuit design and which components do i need
noorb92
Re: pedestrian crossing circuit
Postby pebe » Mon Apr 14, 2014 12:58 pm
What is the max voltage and current from your PV?
$173.56
Power Sentry PS1055LCP LED Emergency Driver Inverter Battery Backup pictureHoymiles HM-300N Grid Support Utility Interactive Inverter Microinverter
$39.97
