Resistance to voltage output
Postby shanakaplus » Fri May 23, 2014 1:52 pm
Hi. I have fuel sensor which gives 240 -30ohm resistance output according to the tank fuel level. When tank is entry 240ohm resistance output and when tank is full 30 ohm resistance output. I want to convert this signal to voltage output such as when tank is empty 0v volt and when tank is full 5v volt output. My supply voltage is 12v. I am going to us this signal to my gps system. Please help me to design a circuit. Thank you.
shanakaplus
Re: Resistance to voltage output
Postby pebe » Sat May 24, 2014 3:21 pm
I assume you will want a linear relationship between resistance and voltage (is resistance linear with contents of the tank)?
What sort of accuracy are you looking for?
$37.00
Raspberry Pi Compute Module 4 CM4 2GB RAM + Carrier Board pictureIntel® UP Xtreme 1145GRE Embedded Dev SBC 32GB RAM 512GB SSD Kit
Intel® UP Xtreme 1145GRE Embedded Dev SBC 32GB RAM 512GB SSD Kit pictureRAM Jack 10 Ton Capacity 10" Stroke Hydraulic Piston Frame Machines & towers
$274.99
RAM Jack 10 Ton Capacity 10Allen-Bradley 1775-ME8 Memory Module
$984.62
Allen-Bradley 1775-ME8 Memory Module picture
