SWP switch?
SWP switch?
Postby lees.lee » Thu Aug 28, 2014 11:33 am
Puzzled for a while for one master (reader) connect to two security elements through SWP.
Q: Is that possible have a switch control by GPIO so the reader can talk to either ONE security elements on the system depend GPIO setting?
lees.lee
Re: SWP switch?
Postby pebe » Thu Aug 28, 2014 2:01 pm
I don't understand your question - it is too vague.
'GPIO' could be a microcontroller port - is it? And there are dozens of definitions for 'SWP'.
What do you mean, exactly?
$169.75
Southwire 28828255 250 ft. 12/2 Solid Romex SIMpull CU NM-B W/G Conductor Cable pictureBurndy KS31 DB T1/0-350 70-185 - (Lot of 3)
$99.99
Burndy KS31 DB T1/0-350 70-185 - (Lot of 3) picture18/6 Shielded Wire 18AWG 6 Conductor 200FT Shielded Plenum Cable White CL3P Jack
$183.82
18/6 Shielded Wire 18AWG 6 Conductor 200FT Shielded Plenum Cable White CL3P Jack pictureCommon Sense Marine MW20-8-100 20/8 AWG 8 Conductor Signal Wire 100 ft Tinned
$230.30
Common Sense Marine MW20-8-100 20/8 AWG 8 Conductor Signal Wire 100 ft Tinned picture
