How to build: simple antenna amplifier for 870 MHz
Postby rexys » Mon Sep 22, 2014 1:28 pm
Hi, I'm trying to build a simple antenna amplifier for 870 MHz. It must be connected to a home automation systems that both send and receive at the same antenna (870MHz) Can anyone help me closer to a diagram of one of these?
Have lots of experience building electronics.
Kind Regards
rexys
Re: How to build: simple antenna amplifier for 870 MHz
Postby pebe » Fri Sep 26, 2014 5:47 pm
Separate amplifiers for receive and transmit would have to be built into the board inboard of the Tx/Rx switch.
Unless you are familiar with the regulations governing these devices, and you are competent with designing at that frequency on small PC boards, then it's a no-goer.
$139.00
ProTeam GoFit 3 Corded Bagged Backpack Vacuum w/ Tools Sternum Clip pictureAnjoy Home 2-in-1 Cordless Rechargeable Bagless Vacuum, 12V + Nozzles
$16.50
Anjoy Home 2-in-1 Cordless Rechargeable Bagless Vacuum, 12V + Nozzles pictureIdex / Systec Vacuum Pump 9000-1892 bench tested and GUARANTEED to work.
$199.00
