Calculate gain and cut off freq
Postby Jay2OR » Thu Dec 11, 2014 9:14 pm
im speakers for my phone i need some help
its a dual stage amplifier circuit using a TL071, to form an active low pass filter with an upper cut-off frequency of between 18 and 25 kHz with and gain matched to the output for my phone, and an OPA551 current amplifier with unity gain.
I checked the datasheet for the OPA551 and found Max current out is 200mA
Speaker impedance is 8 ohms
i loaded a continuous tone on my phone and measured,
Max volume = pk-pk 2.68V
Medium volume = pk-pk 100mV
Low volume = pk-pk 10.30mV
how will i work out the gain? i tried this
200mA x 8 = 1.6V
max volume gain = 20xlog(1.6/2.68) = negative 4.4dB
im not sure if this is right
and then on medium and low i did the same thing and got 24dB and 43dB
Jay2OR
Re: Calculate gain and cut off freq
Postby pebe » Fri Dec 12, 2014 3:06 pm
If you use the OPA551 its 200mA maximum current will be the pk-pk current swing of the waveform. That's +/- 100mA from the centre line of the waveform (= 70mA RMS) and that will give you a maximum power of only 40milliwatts in an 8ohm speaker. Is that enough for you?
You don't say where you measured the maximum volume as 2.68Vpp. Was it measured across the earphone socket?
Lot 6 SanRex PD60KB160 Thyristor Diode Module 60A 1600V on Aluminum Heatsink
Lot 6 SanRex PD60KB160 Thyristor Diode Module 60A 1600V on Aluminum Heatsink picture5000A Phase Control Capsule Thyristor Convex Type SCR Silicon Controlled Ballast
$185.00
5000A Phase Control Capsule Thyristor Convex Type SCR Silicon Controlled Ballast pictureSCR Thyristor SKN6000/04 for Semikron VF1.20V 14KA
$118.84
SCR Thyristor SKN6000/04 for Semikron VF1.20V 14KA picturePower Transistor, Mosfet, Thyristor and Voltage Regulator Assortment Kit, 82
$54.99
