Transistor pinout
Transistor pinout
Postby [email protected] » Tue Mar 17, 2015 4:17 pm
Hello Electronic Circuits Help Forum,
With the flat facet of the TO-92 package facing you
and the three legs pointing down the transistor in the data sheet
http://www.nxp.com/documents/data_sheet/PN2222A.pdf
marked PN2222A has the collector on the left
the base in the middle and the emitter on the right.
https://www.fairchildsemi.com/datasheets/PN/PN2222A.pdf
marked PN2222A has the collector on the right
the base in the middle and the emitter on the left.
So do different manufacturers have different pinouts for
a transistor with the same name?
Is the base always in the middle?
Without the datasheet is there a way of knowing which
pin has which function?
Thanks.
Allen in Dallas
[email protected]
Re: Transistor pinout
Postby pebe » Wed Mar 18, 2015 4:21 pm
[quote]So do different manufacturers have different pinouts for
a transistor with the same name? [/quote]
Both the manufacturers you quote are using the same pinouts for the PN2222A.
[quote]Is the base always in the middle?[/quote]
There are other TO-92 pinouts that are different. Have a look at the 2N3902, where the base and collector are swapped over.
Postby KMoffett » Wed Mar 18, 2015 6:28 pm
I ran into this a while ago. The 2N2222A and PN2222A are one way...the P2N2222A is the opposite.
Note the drawing on the right side. [url]http://en.wikipedia.org/wiki/2N2222[/url]
But, if you do a Google search on the P2N2222A it's shown both ways. :(
CH341A EEPROM Flash BIOS USB Programmer Kit with SOP8 Clip
$12.99
CH341A EEPROM Flash BIOS USB Programmer Kit with SOP8 Clip pictureC15 6NZ High Hp Flash Files
$79.99
***3pk*** ZIP System Liquid Flash 10.3 oz. Cartridge pictureCaterpillar c13 KCB Iva/vva Off Flash Files
$125.00
Caterpillar c13 KCB Iva/vva Off Flash Files picture
