Electronic circuit diagram for Sanwa radio control system
Postby felixarba » Fri Feb 06, 2015 8:52 pm
Good evening to all!
I have an old model of 27 Mhz SANWA digital proportional radio control set for radio controlled models.I bought this set in UK in 1979.Cannot read any type/ model data on the case but most likely will be the model 1F 2S (or 2F 2S) since there is only one joystick to control two servos.
The model is quite old but was working fine and now need some small checking on the printed board.
Would appreciate if anybody can give any info where could be possible to find the Owners manual and electronic circuit diagram.Thks
Radio control transmiter
felixarba
Re: Electronic circuit diagram for Sanwa radio control syste
Postby sourabhpahwa » Fri May 08, 2015 6:40 am
Quite old model SANWA RCS and i have it too. I explored a lot about it and finally stop over at [url]http://www.ijeee-apm.com/Home.aspx[/url] , I hope this will help you somehow, I suggest you to go through this site based on journals and articles on the field of electrical and electronics engineering.
sourabhpahwa
Postby felixarba » Fri May 08, 2015 7:16 pm
Thanks for the message.Will try and maybe fix it.
felixarba
Postby bwetman » Mon May 11, 2015 7:05 am
I explored some printed circuit board repair at [url]http://www.solder.net/[/url]
I hope this will helpful.
This site based on electronics equipment.
bwetman
$139.00
ProTeam GoFit 3 Corded Bagged Backpack Vacuum w/ Tools Sternum Clip pictureAppion Mgavcr Mega Flow Vacuum Rated Valve Core Removal Tool – 5/16 System Conne
$54.50
Appion Mgavcr Mega Flow Vacuum Rated Valve Core Removal Tool – 5/16 System Conne pictureSMD Vacuum Pickup Tool, Foot Operated
$78.00
SMD Vacuum Pickup Tool,  Foot Operated picture
