AC delayed off relay
Postby jack mcleod » Sun Feb 14, 2016 5:42 am
A ½ - ¼ sec. Delayed off of a 120v AC relay is needed. With a DC coil the cap goes in parallel. Can the delay be accomplished on an AC coil using a diode & a cap? If not how?
Thanks, Jack
jack mcleod
Re: AC delayed off relay
Postby KMoffett » Sun Feb 14, 2016 10:45 am
The short answer is no. DC relays depend in the coil resistance to limit the current. AC relays depend on the coil impedance at line frequency the limit the current. Applying DC to an AC relay will cause a much larger current to flow. which may cause excessive heating. And, even if that were tolerable, would require a much bigger cap to create any delay.
What are you switching on/off? Is powered hot and neutral still available at your switch after your load is turned off? There commercial Delay-off modules.
*NEW* JOHNSON CONTROLS P28AA-1C Lube Oil Pressure Cutout Control 120/240 VAC
$125.00
*NEW* JOHNSON CONTROLS P28AA-1C Lube Oil Pressure Cutout Control 120/240 VAC pictureJOHNSON CONTROLS TEC2646H-4 FCU HOSPITALITY THERMOSTAT
$275.00
JOHNSON CONTROLS TEC2646H-4 FCU HOSPITALITY THERMOSTAT pictureJohnson Controls P45NCA-12C Oil Failure Cutout Control-Built-in Time Delay Relay
Johnson Controls P45NCA-12C Oil Failure Cutout Control-Built-in Time Delay Relay pictureJohnson Controls Va-7152-1001 Elec Act, 90 In.-Lb., Proportional, 24Vac
$275.00
