circuit to reverse motor direction, 24v
Re: circuit to reverse motor direction, 24v
Postby H73iiPz » Sat Feb 09, 2013 10:17 pm
If I am understanding you correctly the diodes going across the coils would go across pins 7&8 which plug into sockets A&B? The relay is totally enclosed. Also, I am assuming as the schamatic shows that the cathode is on the +24V side?
H73iiPz
Postby pebe » Sun Feb 10, 2013 2:48 am
I cannot identify the relay. Can you give me a link that shows the connections?
Yes,the cathode goes to +24V.
Postby H73iiPz » Sun Feb 10, 2013 3:48 am
Here you go. R14 - 5A15 - 24 Diagram D10
http://www.nteinc.com/relay_web/pdf/R14.pdf
H73iiPz
Postby pebe » Sun Feb 10, 2013 10:36 am
OK.
7 & 8 are the coil connections, 6 is the common that connects to the motor, 2 is the 'normally closed' contact that goes to 0V, and 3 is the 'normally open' contact that goes to +24V.
Postby H73iiPz » Wed Feb 13, 2013 6:16 am
Have got it wired and just wanted to check theTR1 And TR2 connections. Your directions, "(from he top) C,B,E." To clarify, Is C connected to the diode/coil, B between 6K8 and 2K2, E to 0V??
H73iiPz
Postby pebe » Wed Feb 13, 2013 10:40 am
Yes, that's correct.
Previous
$169.75
Southwire 28828255 250 ft. 12/2 Solid Romex SIMpull CU NM-B W/G Conductor Cable pictureBelden 5200 ue 2 Conductor 16 AWG 428 feet.
$45.00
Belden 5200 ue  2 Conductor  16 AWG      428 feet. pictureCarol Encore Prysmian C1164 Coax, 93 Ohm, 22-SOLID **100 ft.**
$109.74
Carol Encore Prysmian C1164 Coax, 93 Ohm, 22-SOLID  **100 ft.**   pictureSouthwire Company 28827455 Electrical Wire
$114.99
Southwire Company 28827455 Electrical Wire picture
