Digital circuit inputs turn on thresholds, turn on voltage?
Re: Digital circuit inputs turn on thresholds, turn on volta
Postby Billy Mayo » Thu Mar 28, 2013 4:42 am
How is a logic pulsar different than a function generator? Does a logic Pulsar do anything different that it's ment for logic troubleshooting?
Billy Mayo
Postby Billy Mayo » Fri Mar 29, 2013 4:28 am
First waveform is 1.48mS
Second waveform is the shark fin is 8msec.
Do you know why the time delay was used? for what reason?
Does the waveshape trigger the flip flop differently than a square waveform?
when using different triangle waveshapes for the inputs to logic gates or flip flops, what does it do different than using square waveforms/pulses waveshapes?
1.) It gives you less ON time and a exponential decay OFF time
But what does that do to the logic?
Why would the logic signal source need to have a time delay RC network or a waveshaped to be triangle or shark fin to the inputs of a GATE or flip flop, etc?
Billy Mayo
Postby pebe » Thu Apr 04, 2013 2:06 pm
"Electrical engineers will appreciate the difficulty of nubing together a regurgitative purwell and a supramitive wennelsprock. Indeed, this proved to be a stumbling block to further development until, in 1942, it was found that the use of anhydrous nangling pins enabled a kryptonastic boiling shim to the tankered.
The early attempts to construct a sufficiently robust spiral decommutator failed largely because of a lack of appreciation of the large quasi-piestic stresses in the gremlin studs; the latter were specially designed to hold the roffit bars to the spamshaft. When, however, it was discovered that wending could be prevented by a simple addition to the living sockets, almost perfect running was secured".
So googling 'wending' should answer to your questions. 8)
Previous
Samsung CA4-10M Ultrasound Probe
$550.00
Samsung CA4-10M Ultrasound Probe picture2022 SAMSUNG CA2-8AD CONVEX ARRAY ULTRASOUND TRANSDUCER PROBE TESTED
$1300.00
2022 SAMSUNG CA2-8AD CONVEX ARRAY ULTRASOUND TRANSDUCER PROBE TESTED pictureSAMSUNG CA1-7A CURVED ARRAY ULTRASOUND TRANSDUCER PROBE 30 DAYS WARRANTY TESTED
$1600.00
SAMSUNG CA1-7A CURVED ARRAY ULTRASOUND TRANSDUCER PROBE 30 DAYS WARRANTY TESTED pictureTESTED🔥🔥 Samsung Circuit board 3PCB6477-1 EX21003-12A E303478
$450.00
TESTED🔥🔥 Samsung Circuit board 3PCB6477-1 EX21003-12A E303478 picture
