Controling an AC Relay with opamp
Re: Controling an AC Relay with opamp
Postby lowtech » Fri May 02, 2014 1:22 pm
Thank You. I'll give it a try. With the new circuit, can I slightly change the two voltage levels, say +/- 0.5V?
lowtech
Postby pebe » Fri May 02, 2014 5:29 pm
Yes. No problem.
Postby lowtech » Fri May 02, 2014 8:21 pm
Thank you for all your help.
lowtech
Postby pebe » Fri May 02, 2014 11:11 pm
You're most welcome.
Previous
Asco HT8320G202 Solenoid Operated Valve, 120V 60 Cycle, For Air Media
$60.00
Asco HT8320G202 Solenoid Operated Valve, 120V 60 Cycle, For Air Media pictureSolenoid Repair kit for Dentsply Cavitron 124 131, 132, 121, 136, 137, 310, 1000
$39.95
Solenoid Repair kit for Dentsply Cavitron 124 131, 132, 121, 136, 137, 310, 1000 pictureOMKC-2 SPORLAN SOLENOID COIL 208-240V NEW
$39.73
OMKC-2 SPORLAN SOLENOID COIL 208-240V NEW pictureNITRA AVS-5312-24D Pneumatic Solenoid Valve 5-Way/2-Position 24V DC
$80.00
NITRA AVS-5312-24D Pneumatic Solenoid Valve 5-Way/2-Position 24V DC picture
