Remote LED sensor?
Remote LED sensor?
Postby cdevidal » Fri Apr 22, 2011 1:33 pm
It's been 20 years since I'd done anything with electronics but it's like riding a bicycle :-)
I just bought a cheap alarm system that has an LED showing when it's armed on the central unit, which is locked away in a cabinet. We need a remote display for the LED so that we can see the status from outside.
I'd prefer to modify an existing product to save time (doorbell, moisture sensor, etc.)
I think I'll need to clip the LED leads and solder a relay instead. When the relay is closed, send a signal via transmitter to the receiver outside, which has an LED or some other indicator.
The outside unit does not need to be weathertight.
Thoughts?
You're a good person? Yeah, right ;-)
Prove it: TenThousandDollarOffer.com
cdevidal
Postby cdevidal » Sat Apr 23, 2011 11:44 am
I may try simply extending the LED on a long pair of leads out to a window. Hope the resistance is low.
cdevidal
Re: Remote LED sensor?
Postby abdiasis jama » Mon Apr 25, 2011 6:11 pm
[quote="cdevidal"]It's been 20 years since I'd done anything with electronics but it's like riding a bicycle :-)
Thoughts?[/quote]
read this book microelectronic circuits by sedra smith it will give a handfull of transmitters and recievers
abdiasis jama
$14.99
500pc Radial Electrolytic Capacitor Assortment Kit 24 Value 0.1uF-1000uF 10V-50V picture925Pcs Aluminum Electrolytic Capacitor Assortment Kit 36 Values 1uF-1000uF
$45.99
925Pcs Aluminum Electrolytic Capacitor Assortment Kit 36 Values 1uF-1000uF picture25 Values Metallized Polypropylene Film Capacitor Kit 400V-630V - DIY Electronic
$38.99
25 Values Metallized Polypropylene Film Capacitor Kit 400V-630V - DIY Electronic picture40+5 uF ±6% 370V/440VAC Dual Round Capacitor Carrier Lennox Goodman Genteq Trane
$22.99
40+5 uF ±6% 370V/440VAC Dual Round Capacitor Carrier Lennox Goodman Genteq Trane picture
