LED chaser circuit
LED chaser circuit
Postby ferrariracers1 » Mon May 02, 2011 9:35 am
Hello everybody! I hope you all are doing fine!!..
Coming to my problem......I have heard about a 10 led chaser circuit using the 555 timer, 4017b decade counter.....But in Chandernagore, in India, there are professionals who build circuits so as to light up large LED chasing patterns....I just got a glimpse of the circuit and i found out that the following components were present:
1. 555 timer ic
2. 2 capacitors
3. set of resistors with the timer
4. 4017 decade counter ic
5. BC 547 transistors
6. Zener diodes with each transistor(BC547). I dont know the rating.
7. Two resistors after each transistor (green in colour).
8. 2N6107 PNP transistors after each BC547 transistor..
On asking about the working about the circuit the local shopkeeper said that the output comes out from the collector portion of the 2n6107 transistor and that it is a simple led chaser circuit.
I want to build this circuit on my own.....So i need your help to finish this circuit.....I would be highly obliged if anybody of you can give me the exact circuit diagram with these components......
ferrariracers1
LED sequencer w 4017 IC
Postby [email protected] » Tue Jul 26, 2011 12:55 pm
ferrariracers1,
Not sure if this has every one of the components you listed but it has the 555 timers abd 4071 IC
http://www.rficdesign.com/electronics/led-sequencer
Hope this helps.
Allen in Dallas
[email protected]
$149.00
$565.00
$799.99
SOLAR ELECTRONICS MODEL 8012-50-R-24-BNC LINE IMPEDANCE STABILIZATION NETWORK pictureTOA ZM-104 Portable Analog Speaker Line Impedance Meter
$198.95
TOA ZM-104 Portable Analog Speaker Line Impedance Meter picture
