Help with Hi-Striker!! (Scaled LED cascade)
Postby dr.reddog » Wed May 04, 2011 5:13 am
First time poster; hopefully someone can help me out. I'm trying to build a circuit for a LED Hi-Striker. This is my inspiration [url]http://jmillerid.com/wordpress/tag/hi-striker/[/url]
I would really like to generate this result without having to resort to Arduino because I want to do this on the super cheap (I hope to build several for a children's fair in my neighborhood). I don't care about the sounds or flames, I just want a vertical LED cascade that responds to a scaled analog input.
Thanks for any help!!
dr.reddog
Postby admin » Thu May 05, 2011 3:29 am
If you need lots of LEDs (>10) then your best bet would be a microcontroller. Atleast you could have someone do it for you. It would ease the construction greatly.
If you can live with less LEDs (<=10) then there are chips which do this. Here are some links:
http://www.national.com/ds/LM/LM3914.pdf
(read the application hints section on how to expand to more LEDs)
http://www.stefanv.com/electronics/esv.html
regards,
Admin.
admin
Site Admin
Postby dr.reddog » Thu May 05, 2011 4:10 pm
Thank you! This is exactly what I needed! I think what I might try to do is build the circuit with 30 LEDs, but have three LEDs per output. That way the array is larger, but there will only really be 10 'stages'.
dr.reddog
Postby dr.reddog » Thu May 05, 2011 10:13 pm
I realize this chip is a display driver, but would there be a way to connect an electric buzzer to the 10th output pin? I would like to have a buzzer ring (or something else fancy happen) when the scale max's out (ie; 'you win!'). Thanks.
dr.reddog
Honeywell AC Solenoid Valve 50041883-002 for HE100 and HE200
$22.45
Honeywell AC Solenoid Valve 50041883-002 for HE100 and HE200 pictureSolenoid Repair kit for Dentsply Cavitron 124 131, 132, 121, 136, 137, 310, 1000
$39.95
Solenoid Repair kit for Dentsply Cavitron 124 131, 132, 121, 136, 137, 310, 1000 pictureOMKC-2 SPORLAN SOLENOID COIL 208-240V NEW
$39.73
OMKC-2 SPORLAN SOLENOID COIL 208-240V NEW pictureNEW 281291 Vickers Solenoid Coil 115V 60Hz OLD INVENTORY
$399.00
NEW 281291 Vickers Solenoid Coil 115V 60Hz OLD INVENTORY  picture
