Reset Buttons
Reset Buttons
Postby samanthan101 » Thu May 05, 2011 9:25 am
Hello.
I require some help.
Im building a circuit and need to use a reset button. Im using a genie chip (c20) and would like to know weather the reset button should be an input or an output.
Also do i need any other components between the chip and the reset button for example a resistor etc.
Im also using six LED's on my circuit (20mm big lamps) and i am going to run two from each output. What size resistor would i need? If im using a 4AA batterys?
samanthan101
Postby pebe » Sun May 08, 2011 7:57 pm
I have looked up the 'Rapid' site and viewed the datasheet for the IC there. But all it gives is the pinout allocations - and nothing about programming.
I assume you bought the C20 as part of a kit from Genie, so is there nothing supplied by them that would indicate how to use it?
$17.92
$40.50
$225.00
$24.58
