Integrating two oscillator schematics.
Postby Blunderland » Mon May 23, 2011 3:30 pm
I've built the following square wave 555 oscillator circuit:
http://www.scottmetoyer.com/archives/simple-555-synth
I now want to integrate the following saw-tooth wave schematic to create a polyphonic synth:
http://www.electronic-circuits-diagrams ... ages/2.gif
Should I create the separate saw-tooth circuit then simply send it to the same output as the square wave?
Also do I need to use a separate 9v or is there anyway I can use the same one?
I also want to add an on/off switch for the synth, but if they are two separate circuits but just sent to the same output will I need two separate switches?
Any help would be hugely appreciated.
Blunderland
$27.00
$469.95
$299.99
