Electronic dipstick
Electronic dipstick
Postby Allycat » Wed May 25, 2011 3:56 pm
Hi All, I want to make an electronic dipstick which will show low or high oil level, does anyone now of or possess a circuit diagram for this project. Here is abit more info. The dipstick will not be fitted to an engine in a car. The engines will sometimes be hot or cold after a hot bench test. I need to know if the oil fill is low or high. It needs to be done with no moving parts. Indication will be by Green & Red led`s. It needs to fit in approx 6mm hole. Hope this is of use.
Allycat
Postby pebe » Fri May 27, 2011 9:32 pm
Allycat,
There are several more replies over on the other forum you posted on.
$24.99
$650.00
Carrier 342796-75105 - Evaporator coil OEM Replacement Part *NEW IN BOX* pictureBergstrom 500 PSI Condenser Refrigeration A Coil $245 O/B/O
$159.00
Bergstrom 500 PSI Condenser Refrigeration A Coil $245 O/B/O pictureDETYI DG521 Ignition Coil Pack & SP509 Spark Plug Set
$62.99
DETYI DG521 Ignition Coil Pack & SP509 Spark Plug Set picture
