Newby needs some help
Postby hood012 » Thu Jul 21, 2011 1:50 pm
Hi there all,
I am looking to put together a led circuit (6 3mm LED's) that all flash randomly with a tilt/vibration switch. to be powered by 2no. cr2025 3v batteries. it is to fit in a small box 30mm x 40mm can anyone provide me with a simple diagram? i am a newby to all this so if possible instructions for a five year old would be grately appreciated. i have sorced most of the parts from maplins ect... just not sure where to start.
thanks
Phil
hood012
Postby awright » Sun Jul 31, 2011 7:19 am
Your post title should provide some indication of the nature of your inquiry. As it is, there is no clue to induce someone to click on it.
You say you have sourced parts, but don't tell us what parts you have or your general approach. Specifically, what tilt/vibration sensor do you have or do you know about that you hope to use? Does it provide a signal or a contact closure?
Do you just intend to light LEDs to indicate that there has been some activity at the sensor? If so, why are they to flash randomly?
Help us help you.
awright
awright
$5.99
$6.47
5 Set linear Potentiometer Kit 15mm 3Pin B1K 2K 5K 10K 20K 50K 100K 250K 500K 1M pictureAllen Bradley 800T-U41 30.5mm Potentiometer Unit, 50 Kilohms Resistive Element
Allen Bradley 800T-U41  30.5mm Potentiometer Unit, 50 Kilohms Resistive Element pictureClarostat RA30 LASB 100 OHM Wirewound Industrial POT
$14.95
