Design help needed
Design help needed
Postby Scott McKie » Thu Jul 21, 2011 8:08 pm
I have an electronic R&D project and have run into the following problem:
I need to drop +120 vdc to +12 vdc; 300 mA current, and can not find anything on how to accomplish it except for a step-down converter that puts out a -12 vdc output.
How can I change the output to a +12 vdc with the 300 mA capability?
Please help either with a fix for this problem or knowledge of another setup that can accomplish the voltage drop.
Scott McKie
$19.73
$550.00
$169.99
$499.99
