SP24T Analog switch controlled digitally (Computer)
Postby Buzz » Wed Aug 31, 2011 4:08 am
I was wondering if someone knows if there is a switch available which has two inputs 12VDC +,- and about 24 output contacts. I am looking be able to control the switch by computer via USB, serial, paralell, etc. I want to be able to select either if the inputs to any of the outputs separately.
If there is not something with two inputs I could use one input which could select one of 24 outputs which could be controlled by a computer. I am basically looking to control an analog switch with one input to one of 24 outputs by computer. I hope I am not looking for something which doesnt exist I just can not find it. Help!!!!!! Thanks
Buzz
$169.75
Southwire 28828255 250 ft. 12/2 Solid Romex SIMpull CU NM-B W/G Conductor Cable pictureCommon Sense Marine MW20-8-100 20/8 AWG 8 Conductor Signal Wire 100 ft Tinned
$230.30
Common Sense Marine MW20-8-100 20/8 AWG 8 Conductor Signal Wire 100 ft Tinned pictureCommon Sense Marine 18 Gauge 2 Conductor Marine Wire 75 ft 18/2 AWG
$61.24
Common Sense Marine 18 Gauge 2 Conductor Marine Wire 75 ft 18/2 AWG pictureEaton Crouse-Hinds C67 Type C Conduit Body 2in Form 7 Feraloy Iron Alloy
$339.99
Eaton Crouse-Hinds C67 Type C Conduit Body 2in Form 7 Feraloy Iron Alloy picture
