Need help for designing circuit for LEDs of car
Postby moonnightingale » Sat Sep 03, 2011 9:46 pm
I want to simulate a circuit of car in a software. There are three lights on each side of a car. when the car is given instruction to turn, these lights operate in a sequence. First of all inner light then inner two and then inner three and this procedure is repeated. For both right turn and left turn it follows this procedure.
There is also a emergency input (Hazard light) which flashes all six LEDs as on/off/on and so one
I have to design a sequential circuit for above stated
Can u tell me the components which will be used for this circuit
I am using 4017 IC but this IC swiches on only one LED at a time
what i need that first LED glow, then first two and than all three for the turn
which IC i should use
moonnightingale
0.1Hz-100kHz Adjustable Frequency Generator 7.83Hz Schumann Resonance Generator
$17.94
0.1Hz-100kHz Adjustable Frequency Generator 7.83Hz Schumann Resonance Generator picture0.01Hz-200Khz Adjustable Frequency Generator for Healing Schumann Sine Waves Res
$37.99
0.01Hz-200Khz Adjustable Frequency Generator for Healing Schumann Sine Waves Res pictureSystem Sensor HWL-LF Low-Frequency Wall Horn White, 10-Pack
$397.00
System Sensor HWL-LF Low-Frequency Wall Horn White, 10-Pack pictureVariable Frequency Drive VFD Motor Speed Control Inverter 3 Phase 7.5 KW
$135.00
Variable Frequency Drive VFD Motor Speed Control Inverter 3 Phase 7.5 KW picture
