Emitter-detector type circuit?
Postby reddragon12 » Tue Oct 11, 2011 9:44 pm
Doing a project that requires the detection of a mist generated from a human nebuliser, but unsure on a circuit that would detect the mist coming from the device. Any ideas on an sensor that would detect this mist would be brilliant..!!
reddragon12
$7.77
$400.00
Macurco CM-6 Low Voltage CO Carbon Monoxide Fixed Gas Detector & Controller pictureLincoln Variable Voltage PC Board Assembly L5394-2
$380.00
Lincoln Variable Voltage PC Board Assembly L5394-2 pictureAutomated Logic SE6104SP BACnet Control Module SE6104SP HVAC Controller
Automated Logic SE6104SP BACnet Control Module SE6104SP HVAC Controller picture
