My Lawn Mover Project
Postby JangKang » Mon Oct 17, 2011 1:32 am
Before that, our Project is Grass Cutter (Lawn Mover) which its control by RF(remote control) and use electric power. because our scope is Green Technologies.
My Motor for move my project tyre is :
12V DC motor, speed: 10000, speed with Load: 2500rpm
power: 120W-600watt, peak standstill torque = 4.5Nm.
here, i was think wanna use PIC16F877A and L293D and relay to control the motor which its will be trigger by RF (radio frequency).
any one can comment, can advise me, suggest me the programming coding, the circuit diagram that suitable.....
my basic diagram circuit:
RF(Tx)>>>>(Rx)>>>>PIC16F877A>>>>>L293D>>>>>>Relay>>>>DC Motor.
other circuit also is my project require is, motor for cutter pillar.....
[/img]
This basic Block diagram for my project.
Motor is for my (tyre & Pillar Cutter)
Block DOagram.jpg (25.97 KiB) Viewed 5568 times
JangKang
OEM Stanadyne Roosa Master 26214 DB Diesel Fuel Injection Pump Shut Off Solenoid
$75.00
OEM Stanadyne Roosa Master 26214 DB Diesel Fuel Injection Pump Shut Off Solenoid pictureSolenoid Repair kit for Dentsply Cavitron 124 131, 132, 121, 136, 137, 310, 1000
$39.95
Solenoid Repair kit for Dentsply Cavitron 124 131, 132, 121, 136, 137, 310, 1000 pictureJP Fluid Control Solenoid Valve CS1-024DC ST-DA014B030F Electric2/2 24 Vdc coil
$119.99
JP Fluid Control Solenoid Valve CS1-024DC ST-DA014B030F Electric2/2 24 Vdc coil pictureParker GP600 G-23 77310 Brass Solenoid Valve 120V 9W Sukup Grain Dryer USA
$174.99
Parker GP600 G-23 77310 Brass Solenoid Valve 120V 9W Sukup Grain Dryer USA picture
