Transistor circuit
Transistor circuit
Postby enjoyliffee » Wed Nov 02, 2011 3:33 am
Please help me analyse this circuit. My question is this: Why does the LED NOT glow when the base terminal is disconnected ?
enjoyliffee
Postby I_Daniel » Wed Nov 02, 2011 11:31 am
There must be something wrong. I am logged in but see no circuit that you refer to. Your post also does not indicate that there is an attachment !
Postby bcct » Tue Nov 08, 2011 6:23 am
I forgot about the current...
When the transistor is on (i.e. the input signal is logic 1) the current will pass from the +Vs to ground, in other words from the collector toward the emitter.
But when the transistor in off (i.e. the input signal is logic 0) no current will flow through the transistor because it's OFF.
If the output signal is applied to a load (e.g. Resistor RL) the current will flow from +Vs through Rc and then through the load RL to the ground.
bcct
$20.50
100 COMMERCIAL CRYSTAL 10 LB LBS 1.5 MIL Plastic Ice Bag Bags With Drawstring pictureBorescope Camera with Light, 16.5ft Endoscope Inspection,Waterproof Snake Camera
$29.99
Borescope Camera with Light, 16.5ft Endoscope Inspection,Waterproof Snake Camera pictureDental ZIRC CRYSTAL HD Neon Mouth Mirrors with Soft Grip Handle - MADE IN USA
$145.00
Dental ZIRC CRYSTAL HD Neon Mouth Mirrors with Soft Grip Handle - MADE IN USA pictureHakko FX888DX-010 - Digital Soldering Station with Rotary Encoder
$70.00
Hakko FX888DX-010 - Digital Soldering Station with Rotary Encoder picture
