[New to circuits] Need information on TRIAC usage
Postby suneelmekala » Mon Nov 21, 2011 6:55 pm
I wanted to build a AC motor controller using a TRIAC. I have a small AC 220V, 20 RPM motor (I do not have the specification of this motor).
And I have BTA12-600B ST make TRIAC (12 Amps, 600V). Here is the specification of the TRIAC (http://www.datasheetcatalog.org/data...0/109542_1.pdf)
Can I use this TRIAC to control this motor ?
Any help is highly appreciated.
Thank you,
Sun
suneelmekala
Postby I_Daniel » Sat Nov 26, 2011 11:24 am
Check how many Amps the small motor draws. if less than that of the Triac you can safely use it.
Johnson Metasys M4-CGM09090-0 M4 General Purpose Application Controller OEM NOS
$199.95
Johnson Metasys M4-CGM09090-0 M4 General Purpose Application Controller OEM NOS pictureJohnson Controls Metasys DX-9100-8454 Extended Digital Controller Rev B
$35.99
Johnson Controls Metasys DX-9100-8454 Extended Digital Controller Rev B pictureJohnson Controls Metasys Controller CVM03050 Module Board
$138.75
Johnson Controls Metasys Controller CVM03050 Module Board pictureJohnson Controls M4-SNE22000-0 Metasys SNE22000 Network Engine 24V 0.4A
$1900.00
Johnson Controls M4-SNE22000-0 Metasys SNE22000 Network Engine 24V 0.4A picture
