240VAC Coil
240VAC Coil
Postby Ma5on » Thu Dec 22, 2011 5:17 pm
hi im new to designing circuit and ive got a 3phase contactor with a 240vac coil im wondering on how to connect this ive got 240vac going in at A1 do i connect A2 to earth? i think im confusing myself with looking to deeply into this i was wondering if anyone could tell me,
thanks
Ma5on
Re: 240VAC Coil
Postby pebe » Thu Dec 22, 2011 5:23 pm
No, don't connect to earth.
You can connect the 240V coil between Neutral and any of the three phases.
$27.04
$85.00
$13.63
$375.99
