buzzers
buzzers
Postby akisandooja » Tue Mar 13, 2012 4:53 am
which combination of piezoelectric buzzers gives the maximum output??
an answer with a circuit would be appreciated.
thanks!!
akisandooja
Re: buzzers
Postby pebe » Tue Mar 13, 2012 6:22 am
To get the maximum sound volume, connect the buzzers in parallel, ie.the voltage source applied separately to each one.
Re: buzzers
Postby akisandooja » Wed Mar 14, 2012 6:10 am
but i am using the piezoelectric buzzers,which will store charge and later on that charge can be used to run ow power consuming devices
akisandooja
Re: buzzers
Postby pebe » Wed Mar 14, 2012 9:35 am
This reply appears to be at odds with your reply to a similar topic under 'newbies'.
Which one do you think is right?
Re: buzzers
Postby akisandooja » Wed Mar 14, 2012 6:32 pm
the one in the newbies section is right
akisandooja
Re: buzzers
Postby pebe » Thu Mar 15, 2012 7:29 am
So......this thread makes no sense at all !
General Electric 16SB1B2X4 Rotary Switch Type SB-1 TRIP AND CLOSE Indicator
$195.00
General Electric 16SB1B2X4 Rotary Switch Type SB-1 TRIP AND CLOSE Indicator pictureEZ GENERATOR TRANSFER SWITCH - The Original, UL / CSA Approved - Made in the USA
$29.00
$104.99
