Minibox maker
Minibox maker
Postby clasys » Sat Mar 24, 2012 9:55 pm
This one has been wracking my brain for awhile.
Bud miniboxes are the brand name for these great little boxes for decades. However, way back when there was a competitor on much of what Bud made, and somewhat cheaper. I believe they were made in the Bronx, NYC but for the life of me I cannot remember the company name. [Weird brain mode: I think the address was Manida Street, Bx, because it's that weird I remember that useless factoid. They are likely out of business or at least moved from there.]
Back then had little money to do anything, so saving pennies mattered. They were good enough for most things so why not. Because I was in NYC, perhaps they didn't have a national presence.
Also, one of them came in cardboard boxes mostly blue and white with black and white lettering for the part likely stamped on the end panel. [Or is that the way Bud did it? This is over 40 years ago for me, help!]
tia,
cjl [I can work with TTL and before that, and just about anything analog, especially audio or tube radios; I even have a powered vacuum desolderer!]
clasys
$17.92
$40.50
$225.00
$11.06
