Does anyone know how to do this?
Postby Chris230291 » Sun Mar 25, 2012 7:00 pm
Hello. What i want is a circuit that can monitor the voltage on the "+" pin of a 3 pin fan header on a computer motherboard. Then "copy" that voltage and replicate it from an external power source (PC power supply), but with enough current to run anywhere up to 8 fans (for example). My plan is to have one fan connected directly and it's speed controlled by the computer. The circuit will monitor the "+" output and replicate it for other fans, allowing me to run multiple fans at the same speed as the one directly connect fan. I hope that makes sense?
I know nothing about designing electronics, but if someone has a solution i am more than capable of assembling it.
Chris
Chris230291
12V Inline Cord Switch IP67 Waterproof, Outdoor ON/Off Toggle Switch DC SWITCH
$9.99
12V Inline Cord Switch IP67 Waterproof, Outdoor ON/Off Toggle Switch DC SWITCH pictureEZ GENERATOR TRANSFER SWITCH - The Original, UL / CSA Approved - Made in the USA
EZ GENERATOR TRANSFER SWITCH - The Original, UL / CSA Approved - Made in the USA pictureNEW STEARNS SINPAC SWITCH, 472104011UA3 , 115V , CV 40A , 50/60Hz , Cutout 130
NEW STEARNS SINPAC SWITCH, 472104011UA3 , 115V , CV 40A , 50/60Hz ,  Cutout 130 pictureSensor Switch NPP20 PL nLight Plenum Plug-Load Control 120V, 20A
$29.00
Sensor Switch NPP20 PL  nLight Plenum Plug-Load Control 120V, 20A picture
